Wheel alignment on A3 Wheelie bar model
The back wheel on my son's A3 wheelie bar model cannot be properly aligned and always ends up rubbing on the frame.
It seems that the cheap black plastic "wheel holders" are perhaps defective. Without them, the axel goes through and the alignment is perfectly straight (but not rideable since the wheel slides back and forth). With them on, the angle of the axel is off just enough to cause the wheel to always rub.
Has anyone else had problems with this? My return window has closed, and when I contacted support they said they can't help me since there is not a Razor dealer in my region.
What options do I have to make this rideable, with or without the wheelie bar? I thought that the wheel assembly kit of an ordinary non-wheelie bar model would work, but I don't want to order one if it will not fit. Again, support refused to give me any advice about this!
Thanks in advance for any advice! I really appreciate it!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
