Salta al contenuto principale
No image from the screen
Computer is on but their is no image from the screen (the screen is completely black) and the screen mirror is not block
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
@kingmalus please clarify what you mean by this "the screen mirror is not block". Next connect an external monitor to your computer and see if that displays correctly. If it does, you know it is your LCD. If it does not, the issue will be with the GPU on your motherboard. Let us know what you find out.
Punteggio 0
Hey, that sucks! If your screen’s black but the computer’s on, try turning it off completely and then back on. Sometimes it just needs a quick restart. Also, check if the brightness accidentally got turned all the way down.
Punteggio 0
Aggiungi la tua risposta
King malus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 43
