Why is my poweradapter Overheating?
I Have battery issue my battery wotrks but my pc suddenly shut down when the battery is less than 50 percent can you help me
Questa è una buona domanda?
C:\Users\<YourName>\battery-report.html).👉 If Full Charge Capacity is much lower (like 50–60% of design), your battery is worn out → needs replacement.
Sometimes the issue is calibration, not health.
If calibration doesn’t fix it, and the report shows degraded health, you’ll need a new battery.
This is also common with older HP laptops.
Causes:
Fixes:
⚠️ If your battery + adapter are both faulty, sometimes the adapter overworks to charge a failing battery → causing overheating and shutdowns. Replacing the battery often reduces adapter strain.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 52
