Salta al contenuto principale
The Nokia 2630b is basic phone with a VGA camera.
4 Domande Visualizza tutte
NOKIA 2630b BLIND SCREEN
AFTER A 80 CM FALL MY NOKIA 2630b'S SCREEN IS BLIND, BUT THE PHONE SEEMS TO WORK WELL. COULD IT BE A SCREEN BAD CONTACT ? IS IT POSSIBLE TO CHANGE THE SCREEN ? ARE THERE WELDS TO BE TAKEN OUT, OR JUST DISCONNECTING AND CONNECTING ELEMENTS ?
Questa è una buona domanda?
Punteggio -1
1 Commento
Monteiro, all caps means you are YELLING ;-)
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Monterio, the first thing that you may want to do is to look at this guide It will show you how to get to your LCD. I would check for a lose connection of the flex cable. If it is still connected, look for any obvious damage to the logic board and the display. Replace the LCD if nothing obvious is found. You can also get the complete service manual for your phone from here. Hope this helps, good luck.
Punteggio 2
Hi,
First of all i would love to suggest you visit bb-parts.net and get relevant information about these topic.
Hope you will solve your problem.
Punteggio 0
Aggiungi la tua risposta
Monteiro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 751
