replacing the battery MacBook Pro (14 Zoll, 2021)
Hi everyone,
I’m considering replacing the battery of my MacBook Pro 14” (2021, M1 Max) myself at some point.
I’ve heard that the batteries in this model might be “paired” with the logic board, similar to iPhones, and that after a DIY replacement in macOS it may show “Service Recommended” even if the battery is technically working fine.
My questions are:
Is it true that Apple pairs the battery with the hardware on the 2021 MacBook Pro?
If yes – can an iFixit battery still be used normally, just with that warning message?
Has anyone experienced whether the “Service Recommended” message stays permanently or goes away?
Thanks!
Questa è una buona domanda?
Your question revolves around Apples use of parts serialization! Similar to what John Deere has done with their tractors. Within the iFixit news feed via the link above you can learn more on it.
As far as the MacBook batteries the source of the battery often times is the issue as in China you'll find people rebuilding batteries by MacGyver a bunch of cells from old sets which are still good into a workable battery! But the BMC logic within this battery will still report a worn out battery.
Using a fresh battery with a clean BMC chip will get you 90% of the way but sometimes SMC logic won't refresh the OS temp files so you need to manual delete them.
da DanJ
