Salta al contenuto principale
Why is 1/4 of my screen black
when I bought my PC they said that part of the screen was black. It's not so bad you can kinda see through it but it would be nice to be able to see that part of my screen.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
It's usually the LED array - I've had it happen on an E6440 and it's usually a replacement LCD :-(. Sometimes you can service the strip but the modern LED panels that they use now which are sealed with tape are all disposable with no serviceability. The bridge screens like some early transition machines where they used a CCFL driver to run the panels can sometimes be fixed (as well as the early post bridge panels), but ANY of the thin ones that came out since ~2014 are disposable. You have to replace the screen as a unit. The HP Spare# is N65679-001. This is a $700 part.
Here is the SM if you want to do the repair: https://h10032.www1.hp.com/ctg/Manual/c0...
Punteggio 1
Aggiungi la tua risposta
Hunter Wrights sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 53
