Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
No Backlight
i need help on how to get back the light on my iphone it is very dark and i know it is the backlight problem but i need help to know how to fix it im scared to open it apart and miss the whole thing up!!!! please help!!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Layla. It seems you might need to replace the Display Assembly. Feel free to use our guide and let us know if you need any help. Best of luck!
Immagine Replace a scratched or cracked front glass panel or a malfunctioning display for your iPhone.
Prodotto
iPhone 3G Display Assembly
$59.99
Punteggio 2
1 Commento:
Although replacing the entire display assembly is undoubtedly the easiest solution, particularly for the less tech inclined, it may not actually fix the issue. Replacing the components responsible for this function is likely to be what's required. But, it does entail desoldering and soldering of 1 or both components on the mother board. See this source, it provides a great zoom pix of component location http://www.amazon.com/CyberDoc-LLC-iPhon.... You can buy both components very reasonably or separately from a NYC vendor.
da
Aggiungi la tua risposta
layla ahmed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 986
