Salta al contenuto principale
Repair guides for the business model of the seventh generation of Microsoft's Surface Pro. The Surface Pro 7+ was debuted for consumers on September 22, 2021.
Is the battery replaceable on the surface pro 7 plus
What kind of connection is it? And how does it connect to the logic board?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
The Surface Pro 7+ (1960, 1961) has the battery connection on the back side of the motherboard. Therefore, battery replacement requires removal of the motherboard. Thank Microsoft for a big step backward from the 7 which uses a conventional plug connector.
Punteggio 1
Hello,
I also have a surface pro 7+ from a business. With regards to battery replacements, i'd assume it's similar to the surface pro 7 it is based on, where you have to remove the display, shields and heatsink to then remove the adhesive held battery. I did notice that the internal layout on the 7+ appears different to the 7, likely based on the fact of 11th gen v 10th gen, however the process to remove should be similar (microsoft tech on here, do you have an answer?)
Pretty much:
  • Remove the display with plenty of heat & a small guitar pick
  • Disconnect the display & battery
  • Remove screws & clips holding heat shields (be careful, remember where the screws go as i'm sure they are all different lengths)
  • Remove heatsink (reapply thermal paste before you reassemble)
  • Remove the entire motherboard & all major components (speakers, cameras, all cables etc)
  • THEN and only then can you squeeze IPA into the gaps & let the adhesive release
  • Lift battery out & place new one in
  • Reassemble the way you took it out (motherboard, components, cables etc)
Let me know how it goes or if you have any other questions :)
Punteggio 0
1 Commento:
The removal process seems simple enough. Its the type of connection the battery has, it doesn't appear to be a pin type connection.
da
Aggiungi la tua risposta
Eduardo Aguirre sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 45
Tutti i Tempi: 180
