Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
iPhone 3G gets down when not connected
iPhone 3G was working fine on iOS 4.2.1
suddenly, due to some reason, its getting crashed/not working with just a blank screen.... no hard reset !!
and then if plugged in charger or USB, Apple icon comes in and after few minutes, its working absolutely fine till its connected either to charger/USB.
Initially, i wondered whether its battery problem, but... once iPhone is in on state... battery percentage is Max.
I tried restoring it but no effect on my issue.
please advice...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If only works with power connected, USB charger or computer. I would try a new battery.
Punteggio 1
I would try to replace the battery and the dock connector. It also could be a short in the phone. I had a similar issue on an iPhone 4. When I took the phone apart and disconnected the battery and the charging dock and plugged it back together it worked fine.
Punteggio 0
Aggiungi la tua risposta
Sameer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 376
