Salta al contenuto principale
How do I replace an inverter?
Dell Latitude D810 Laptop/Notebook This is what I am needing and inverter for.
Also have a Dell Latitude D810 Laptop/Notebook with a screen problem.
turns on with a pinkish tint on the screen then the screen turns off. Is this an inverter or back light? Or do you know.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The pink would indicate a failing ccfls in the LCD. If you can still see the screen dimly when it goes off, it's usually the inverter.
Punteggio 2
1 Commento:
Whats is this? Where is it? a failing ccfls in the LCD
da
Aggiungi la tua risposta
Walter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 544
