Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air da 11" di Apple offre processori Intel Core i5 e i7 di quinta generazione, con un leggero aumento delle prestazioni e della durata della batteria.
如何装Windows系统 How to install Windows system
Mac book air 如何装Windows系统
How to install Windows on Macbook air
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Within macOS you have BootCamp which allows you to run Windows within a VM. This is the preferred way as you can jump between the two OS spaces allowing you to cut and paste data between. Here's more on BootCamp Install Windows 10 on your Mac with Boot Camp Assistant
The other way is to run Windows straight up, completely wiping macOS completely off and just treating the system as it was another Windows system. You do loose access to Mac services like diagnostics and SMC info. I really don't recommend doing this unless you have a second drive setup with macOS so you can boot up under it.
Punteggio 0
Aggiungi la tua risposta
给你个白眼,自己体会 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 37
