Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
745 Domande Visualizza tutte
MacBook Pro doesn´t turn on but charges the battery
Hello
i have a Macbook Pro Mid 2009 13" and the problem is that it wont turn on. When i press the Power button nothing happens, its dead. But the battery charges and the LED on the left side shows the battery status.
Can you please help me?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Have you spilled anything on it?
da
No i didnt spill anything on it.
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Your power button could be non functional. You could remove the bottom panel, disconnect the top case ribbon cable from the logic board then trigger the two power pads on the logic board to power up the machine. If the machine starts up then you know your top case is in trouble.
Punteggio 3
2 Commenti:
I'm assuming by top case ribbon, you mean the one on the top right after opening the bottom panel, with battery close to you. But where are the 2 per pads on the logic board to power up the machine?
da
Question, does this fix the button or merely turn on the macbook ?
da
this might help
http://support.apple.com/kb/TS1367
Punteggio 2
3 Commenti:
Tried to reset but it didn't work. The light of the power cable didn't change.
What else can i try?
da
Move your Moniter in different angles while pressing the power button
da
It doesn't help because nothing happens when I press the power button, no fan noise, nothing
da
try one of these solutions
http://youtu.be/Igspc4eymuQ
Punteggio 0
I have a problem that my mac doesnt turn on and the battery shows the signe that ok and it charged normaly but when i press to turn on he make like when noise and exactly iheart it coming from the hitachi how you could help me please?
Punteggio 0
Aggiungi la tua risposta
Fuad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 38,766
