Salta al contenuto principale
Lanciato sul mercato il 16 settembre, il top di gamma "più piccolo" di Apple ha uno schermo OLED ProMotion da 6,1 pollici, un sistema di fotocamera posteriore a tre obiettivi, il 5G e un'"isola dinamica" di nuova progettazione intorno alla fotocamera frontale e i sensori superiori. È il successore dell'iPhone 13 Pro.
Can the backglass cover be replaced?
My son's iPhone 14 Pro fell and got its back glass cover shattered,
Is it possible to replace it?
He is telling me that to fix it, only the screen and the battery can be reused, and everything else needs to be replaced.
Is that correct?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The 14 Pro can have the back glass replaced, but typically its something that Apple would replace most of the chassis for It's called a rear System, which would basically keep the screen and camera from the existing phone, but get new everything else. In fact batteries will always get replaced if they are removed in a repair by Apple.
Depending on how bad the break is,m its possible that other parts were affected, but likely a third party shop could replace the back glass for you for a reasonable price. There re sometimes some issues with the wireless charging coil. Because of Apple repair complications, but any respectable shop should be able to handle that. The 14 and 14 Plus have a much easier process. the 14 Pro and Pro Max are actually the last iPhones to have difficult back glass repairs.
Punteggio 4
Aggiungi la tua risposta
LRA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 23
Ultimi 7 Giorni: 152
Ultimi 30 Giorni: 815
Tutti i Tempi: 3,155
