Salta al contenuto principale
Lanciato sul mercato il 16 settembre, il top di gamma "più piccolo" di Apple ha uno schermo OLED ProMotion da 6,1 pollici, un sistema di fotocamera posteriore a tre obiettivi, il 5G e un'"isola dinamica" di nuova progettazione intorno alla fotocamera frontale e i sensori superiori. È il successore dell'iPhone 13 Pro.
What is this small flex cable in iPhone 14 Pro speaker?
Hey everyone,
While disassembling my iPhone 14 Pro, I accidentally tore off this small flex cable located in the bottom speaker module. I've marked it in the attached photo.
Does anyone know what this cable is for? Is it critical for audio output or something else?
I'm trying to figure out if I need to replace it or if the phone will work fine without it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I figured it out – the flex cable I accidentally ripped is just a ground connection, and it only contains a single electrical trace inside.
I verified this using a multimeter in continuity mode: I placed one probe on the trace from the flex cable and the other on the iPhone’s metal frame – and got a beep, confirming they’re directly connected.
So it's most likely there to ensure consistent grounding. The speaker and phone seem to work fine without it.
Hope this helps someone in the future!
Punteggio 0
I think that's a feedback microphone, it prevents the echo when you are talking with hands free use.
Punteggio 0
You will need to fit a new charge port assembly if you have problems.
Punteggio 0
Aggiungi la tua risposta
Fabian Olczak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 130
