Why is phone adaptor over heating
Questa è una buona domanda?
Maybe it doesn't support the voltage in your country.
ALL modern chargers are 100-220V - 50-60Hz, so there isn't a country issue.
Many phones no longer come with a charger, therefore it is likely the charger you are using is under powered.
If the charger isn't rated to supply as much CURRENT as the phone wants, then it will max out at its rated CURRENT and overheat.
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 49
Tutti i Tempi: 824
Is it official one and is it supporting voltage that's in your country?
da 51515
Best adaptor
da Deepak Samantray
There is a problem with 5G internet on mobile.
da SADDAMALI THANDAR
Charger pin fault
=== Update (03/13/26) ===
How to change Charger pin
da Balram Dansena
