Why is my mower idle low and barely cuts without dieing
Why is my mower have a low idle rpm and never comes up. Also dies if cutting any grass taller than 1 inch
Questa è una buona domanda?
Hi Randy,
While you may get some generic answers by just telling us you're working on a lawn mower, chances are you'll get a much more specific answer if we know the manufacturer and model number of your particular lawn mower. I suggest editing your post to add that information to get some better responses.
As an example, if I knew the model number I wouldn't have to ask if this is a gas or electric mower. Assuming it's gas, have you removed the air filter and cleaned it or at least tried to run it without? Does it have a fresh tank of gas? Have you checked anything in the carburetor, such as the needle valve or float bowl? How about the spark plug; did you try cleaning it and checking the gap?
What have you done to try and troubleshoot the problem so far?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 53
