Salta al contenuto principale
The DeWalt DWD450 is a corded 1/2" 11 amp right angle drill.
How do I wire up the vsr trigger switch
I have a new switch I need to install on the drill bit don't know how to wire it
A
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I don't know if wiring diagrams are available for your drill, but generally my process is to open the drill up to get to the switch, then use the existing switch as a guide to where each wire goes. Take one wire at a time and move it from the original switch to the corresponding point on the replacement part. Is there a reason that won't work for you?
Punteggio 1
2 Commenti:
To much time between new switch arriving. Took old switch out to get part number and. Don’t remember sequence to put back
da
@tony20811 How many wires go to the switch?
da
Aggiungi la tua risposta
Matt Littlejohn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 76
