Salta al contenuto principale
Lanciato a novembre 2020, il MacBook Air da 13" usa il SoC (sistema su chip) basato su ARM M1 di Apple, con una CPU octacore e una GPU che può arrivare fino a octacore. (Modello A2337 / EMC 3598 con due porte Thunderbolt 3)
Important Data Recovery But Device is Broken
I had transferred some important videos from a trip onto my M1 Macbook air. However when i went to edit it shut down randomly. I couldnt turn it back on! It was wayyy past warranty so no Taking it to the apple store. The device is not working and not charging. Is there any way to recover data? Like no need to fix it (bc its too expensive) but just the Data
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The SSD storage on these models is soldered onto the logic board, so if the unit is showing no signs of life then you will not be able to access the data that it is holding. Until the unit has powered on we cannot diagnose if the problem could be from a dead battery. It would need to be checked over by an experienced technician to see if there is some shorted circuit or other issue, that is if you didn't have the tools and know how to investigate the issue yourself. Sorry for the bad news.
Punteggio 0
Aggiungi la tua risposta
RyanJoseph sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 64
