Why is my PC charging but not powering on
Questa è una buona domanda?
Probably a Problem with the Motherboard. If you hear a Fan Spin, its probably the Screen.
If your laptop shows charging but won’t power on, try these quick checks:
We see this often with EliteBooks, and many times it’s a simple power reset or RAM reseat. If not, it usually points to a board-level issue.
@abdullahideeq @kevin11129 you have not told us how old your battery is. Your PC may say it is charging but a dead battery will not hold a charge. I'd start with a new battery and go from there. If nothing else, it will provide you with a known-well starting point for any further troubleshooting, if necessary. Use the HP EliteBook 645 G10 Maintenance And Service Guide to work on it.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 305
1 Commento
My laptop charging but don't working when unplug the charger it is of
da Abdullahi Deeq
