Salta al contenuto principale
My phone refuses to charge instead it’s heat up.
My phone refuses to charge. Instead of charging it rather heats up. I have changed the charging port but still same thing keeps happening. Does anyone know how to fix this.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
My phone refuses to charge instead it heats up
da
@ashurahabd37940 same question = same answer. Follow the steps in the original answer.
da
Aggiungi un commento
1 Risposta
@simon97127 generally heat = Short circuit. You did not tell us if you've changed you battery. That would be the first suspect. After that it is possible that you have issues with the power management IC. For that you will need the schematic and board view for your circuit board.
Punteggio 0
Aggiungi la tua risposta
Simon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 87
