Salta al contenuto principale
Il processore Core 2 Duo da 2, 2,26, 2,53 o 2,66 GHz utilizza RAM DDR3. Il processore grafico è FX9400 con 128-256 MB di VRAM a seconda della RAM di sistema installata.
No startup chime/audio greyed out on late 2009 Mac mini?
On my late 2009 Mac mini (Lion 10.7.4) the audio is randomly greyed out without any startup chime. In System Preferences/Sound/Output, no audio output device is shown.
What could be the problem?
Questa è una buona domanda?
Punteggio 1
4 Commenti
Has the unit ever been operated on?
da Condividi
Yes.
Just wondering. Could it be related to overheating?
da Condividi
This doesn't seem like it would be related to overheating.
da Condividi
I’m having the same issue with my late 2009 Mac Mini, which is on the last officially supported OS, MacOS X 10.11.6. I have another more upgraded one that isn’t slow that does have audio, but isn’t booting.
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
You may have a damaged or disconnected audio board. Use this guide to open the computer and get to the board. Check the ribbon cable coming from the interconnect board is connected to it. If the cables aren't the problem, you may need to replace the board itself. Here is one for sale on eBay, as iFixit does not sell them.
Punteggio 2
If you have upgraded your OS to Lion or (especially) Mountain Lion, this can cause your problem. Look in Apples support section for details, but all I had to do was reinstall the new OS... Problem solved.
Punteggio 0
Aggiungi la tua risposta
Michele Carlo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 19
Tutti i Tempi: 3,750
