Hole in suction tube between floor rollers/wheels
I have a hole in the vacuum tubing that goes from floor head to the adapter pole, it's directly between the floor rollers. I don't know what necessary tools I need to access the tubing that requires repair. Any help would be phenomenal..thank you in advance for any help. I'm on my 3rd corded stick vacuum from shark, they are excellent vacuums that absolutely fall apart after a month in use. Little pieces just start to give out cause they're made of plastic. Mighty expensive to be using substandard materials. But a hole in the hose i can't acess is driving me nuts.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
