Salta al contenuto principale
How to connect the battery to a charging PCB?
I bought a new battery for my iPod Nano 5th gen. Unfortunately, the connecter with 3 holes on the new battery was damaged during installation. I now must use a battery pcb from my old battery. But.... Questions: The battery's positive (+) must be connected to which terminal on the pcb as it was not clearly marked (please see attached picture)? Please help and thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@warrenfu should connect to 1. Just remember that you need to flip the board toward the battery component toward the battery and the brown paper to the outside. The battery control board kind of lays on top of the battery. The flex part that needs to be solder points away from the battery.
Punteggio 1
Aggiungi la tua risposta
WarrenFu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 59
