Salta al contenuto principale
Xiaomi Redmi Note 13 5G Released 2024, January 10 174.5g, 7.6mm thickness Android 13, up to 14 128GB/256GB/512GB storage, microSDXC
Why wont my phone turn on
my phone froze then i could not turn it off charge or even move then it just whent black
Questa è una buona domanda?
Punteggio 0
2 Commenti:
My phone got lost in water for around 30 minutes, after retrieving it. It was fully working although signs of water was showing inside the camera. After 3 days it turned off completely I've changed the screen check the circuit board I'm now thinking it's the ribbon of the phone, Seeking some help.
da
Perhaps the battery or motherboard soc is damaged. You can go to the nearby Xiaomi home or make an appointment for maintenance at Xiaomi official website.I hope I can help you!
da
Aggiungi un commento
1 Risposta
First pull the battery and try to turn on phone. (Drains capacitors) Then reinstall battery and put phone on charger.
If phone does not start try replacing battery and or charger with new cable.
Last contact manufacturer to see what they recommend.
If you got phone wet, pull battery and place in bag with rice for 48 hours .
Punteggio 0
Aggiungi la tua risposta
ruaan van rhyn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 66
Tutti i Tempi: 498
