Salta al contenuto principale
L'Apple Watch Series 1 è una revisione dell'Apple Watch originale ed è stato annunciato il 7 settembre 2016. La maggior parte dei componenti è la stessa del Series 2
Apple Watch Erase all Content and Settings Loop
I'm experiencing an issue with my Apple Watch Series 1 (38mm). Every time I turn it on, I get a prompt with two options: "Erase all content and settings" and "Cancel."
When I select "Erase all content and settings," a progress ring appears, but just before it completes, the watch restarts and shows the same prompt again, creating an endless loop. If I choose "Cancel," nothing changes—the prompt still reappears, and the cycle continues.
Additional details:
  • The watch only turns on when connected to the charger.
  • The side button is not working.
  • Pressing the crown without the charger only shows the Apple logo for a second before shutting off.
  • When clicking "Erase all content and settings," the watch must be plugged in, or else it shuts off after showing the progress ring.
Does this suggest a faulty battery? I’m a student, so replacing the battery is my only budget-friendly option. I can’t afford to upgrade.
Has anyone faced this issue before? How did you fix it? Any help would be appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Well you can try the following:
1. Force Restart the Apple Watch
2. Try Using the Apple Watch App on Your iPhone
3. Restore Using Recovery Mode (if needed)
4. Check for Updates
Punteggio 0
1 Commento:
I cant force restart the watch. I cant update it because of this issue. Im stuck at this
da
this problem unsolved since more than 5 years.
Punteggio 0
Aggiungi la tua risposta
Marbert Bacanaya sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 123
