Salta al contenuto principale
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
How to repair GPU
GPU killed itself about 2 years ago and I've found no one willing to repair/replace it or tutorials online. If it really is impossible to fix, how should I go forward? This thing has too much precious data to lose
Questa è una buona domanda?
Punteggio 0
2 Commenti
@turkeylegs lets see if our game console Guru @dan0 has any ideas on this one.
da
Sorry for the late response again, my friend.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@turkeylegs on your 360 S the GPU is part of the CPU. It is not impossible but will require to have the tools to do a total reball. That means you would at minimum need the stencils, a BGA reflow machine and a new processor. That is where you run into trouble. Those do no longer exist. That means you would need to use an old/used processor. Nobody can/will work with processors that nobody knows anything about. Think about it, you may be buying somebody else's problematic chip.
Punteggio 1
1 Commento:
I totally agree! So, the best thing to do is to buy a known working motherboard in this case. It IS more expensive… but will save you a lot of time as it is way easier!
da
Aggiungi la tua risposta
Turkeylegs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 174
