Solder for battery replacement
What type solder should be used on i pod 1 to solder the battery?
Questa è una buona domanda?
Menü
Le tue impostazioni
Dean Silhanek, try this. Always check on the "Tools" section of the repair guide you are using. It will tell you which tools and material to use. Hope this helps, good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 674
