Salta al contenuto principale
The MSI GP62MVR 6RF Leopard Pro is a gaming laptop released in 2016. It features a red outline and the MSI logo displayed on the cover. Serial Number: K1610N0067741
About the CMOS stack
Hi, I wanted to know where I can find the KTS 67 CR 1220W 3.V CMOS battery? And where to buy it, because I'm seeing different models, and I don't know if they're right for this computer.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@davidherna88348 that will be a common CR1220W 3V Lithium battery. You can get one like this and splice the wire to maintain your connector. Of course, you can also look at places like this and even Amazon sells them for a small fortune. So, always be aware that you can get poked in the eye :-) The only thing that matters for this battery is that it is a CR1220, because that is the physical size and that it has 3V. Stay frugal and save your money.
Repair is War on Entropy!
Punteggio 2
2 Commenti:
And is the connector a JST or Molex? I can't quite identify it, and is it 1.25mm? Thank you very much.
da
@davidherna88348 the expensive batteries are the once that supposedly fit your motherboard. So that means that whatever is on your board should be compatible. I like „cheap“ and just connect the wire from the old battery to a new one by splicing. That way I do not rely on OEM batteries and save my hard earned money. :-)
da
Aggiungi la tua risposta
David Hernando sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 20
