MacBook won't turn on after HDD replacement
I tried to update HDD yesterday. While that procedure, the rubber with holds HDD has moved and I could not get the HDD back in. So I gone mad and tried to remove the rubber with a knife. Took long time and I have not always hit the rubber but the metal of HDD shaft. May I cause s short circuit of LogicBoard?
Questa è una buona domanda?
2 Commenti
Are you talking about the rubber bushings that the screws pass through to anchor the HD to the systems frame? Which side did you do this to the HD or the system frame?
da DanJ
Hey Dan,
I am talking about the bushings with anchors the HDD. After I first tried to reinsert the HDD they were gone into the back of the HDD shaft (were the Connectors are) and I needed to pull them out, I did it with a screwdriver and a knife (think that was my mistake). Now it wont turn back on, no reaction at all. But charging works
da Robin Dieker
