Salta al contenuto principale
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
Will replacing the battery resolve kernel panic: TG0B missing sensor?
I have a repeating kernel panicking iPad Pro 2016 and have seen in the panic logs that it’s missing the TG0B sensor. This seems to be a thermal sensor related to the battery.
I have been searching online whether this is fixable by replacing the battery and got mixed results. One website says that the BMS (which might contain the TG0B sensor?) is not located on the battery module and that this is a logic board problem. Another website says that this should be fixed with that new battery module.
Can anyone confirm whether replacing the battery has resolved the kernel panic?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
After opening the iPad, i found that it had been opened before. I could tell as the logic board had missing screws, the battery has been replaced before, some plastic parts were missing and the external keyboard connector was severely bent. After further disassembling the iPad, i noticed that the battery connector on the logic board had a pin missing as outlined in this image from the iFixit repair manual:
I think the previous “repair” guy wasn’t careful enough and had broken the pin that was used to monitor the TG0B thermal sensor.
Punteggio 0
Frequent kernel panics due to thermalmonitord, missing sensors: TG0B - iPad Air 2 Wi-Fi - iFixit
Punteggio 0
Aggiungi la tua risposta
Mathijs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 132
