Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
Domanda Chiusa
Touchscreen not responding
I recently had the screen replaced on my phone after it shattered. I dropped it again and the screen came off in one piece. I put it back on and the home button is responding but the touch screen is not. Is it possible to fix on my own?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
Try removing the display and check if there is Amy damage on the connector or cable attaching it to the phone.
Punteggio 3
sarah langley, sure you can . Here is the guide iPhone 3G Front Panel Assembly Replacement and take a look at it. Verify that all cables are still attached and in good working order. If those are okay, I would suggest to change the front panel. I personally prefer the whole assembly, since it does work easier and quicker. hope this helps, good luck. Hope this helps, good luck.
Punteggio 3
1 Commento:
Totally off topic but today I found the cheapest iphone display assembly's (4 and 4S) The company (centrix) I have ordered from once before, they were good ad I received the item but it was a couple years ago
http://www.centrix-intl.com/details.asp?...
da
About your last post, for some reason I cannot post comments, it doesn't allow me to. I had this problem after I tried fixing the home button. I actually tried doing everything here, and it turned out that the connector pad was broken. Had to take it to Apple store to be re-soldered.
Punteggio 0
I did this a couple of times. I opened up the phone, closed it, and after 3 times of repeating this, the screen was half responsive, and half was not. I opened it up again, and it turned out that connector 2 was slightly loose, thanks for the answers.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 390
