Salta al contenuto principale
Why is blender jar making noise and leaking drops
Why is the blender jar making noise and leaking drops
Questa è una buona domanda?
Punteggio 0
1 Commento:
Why is my car making noise and leaking drops????
No one can give me a good answer.
Maybe you could do better with your question, ya think?
da
Aggiungi un commento
1 Risposta
The sound you hear could be the bearings in your blade assembly in the container going bad. With the leaking in addition, you may want to invest in a new container. The worn out bearings in your blade assembly may have caused the assembly to move during use and worn the plastic causing the hole at the bottom to widen. When you get the new container replace your drive socket too.
Punteggio 0
Aggiungi la tua risposta
zakayo chacha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 95
