Salta al contenuto principale
Repair guides for DJI's 3rd lightweight mini drone. The DJI Mini 3 Pro was released in May 2022. Model number: CP.MA.00000488.01.
7 Domande Visualizza tutte
DJI RC remote batteries drain after 45 minutes
I have the DJI RC that I use with my drones. The battery life should be 2-4 hrs but I only get about 30-45 minutes of run time on mine.
In the past I’ve drained the batteries until the remote shuts down, then I’ve opened the remote and unplugged and replugged the batteries. After that the remote shows that it has about 65%-70% battery left, when I haven’t even recharged it from the first time. The remote then works great for a few more weeks, then it starts having issues again.
Any ideas to why this happens?
Is that because of bad batteries?
Bad software? (I’ve factory reset it 2 times)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would suspect the battery contacts might be corroded. Corrosion will cause a high resistance that reduces the voltage to the unit making it think the battery is low. Removing and replacing the battery cleans some corrosion off making it work again - for a while.
See if you can clean and tighten the contacts.
Punteggio 0
1 Commento:
I double checked, no corrosion.
da
Aggiungi la tua risposta
Nate sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 14
