Salta al contenuto principale
Il top di gamma di Apple per il 2022. Lanciato sul mercato il 16 settembre, l'iPhone 14 Pro Max sfoggia uno schermo ProMotion OLED da 6,7", il nuovo chip A16 Bionic, un sistema di fotocamera tripla e connettività 5G. È il successore dell'iPhone 13 Pro Max.
Static noise on video recording from back camera.
Hello.
My iPhone 14 pro max has a really bad video sound recording from back camera.
When I record a video with any of the back cameras the sound quality is really poor. It’s recording a real bad static noise.
Changing the settings for the video recording its not helping.
Is there a solution for this problem?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Did you get the phone excessively wet? Is the display slightly pulled from the case creating a gap for water to enter?
da
No my phone is in perfect condition.
The phone is dry ,never was in contact with water.
da
Aggiungi un commento
1 Risposta
Well, that only leaves the front facing microphone is part of the earpiece iPhone 14 Pro Max Earpiece Speaker if you look at the image of the part you’ll see two gasketed openings one is the earpiece speaker the other is the microphone.
It’s likely the microphone is bad. Do you still have AppleCare? If you do this would be covered under it.
Immagine Replace an earpiece speaker compatible with the iPhone 14 Pro Max model A2651, A2893, A2894, A2896, or A2895. Fix problems with phone call audio.
Prodotto
$29.99
Punteggio 0
Aggiungi la tua risposta
Dimitar Timev sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 224
