Salta al contenuto principale
Una console portatile rilasciata da Valve. Lanciata sul mercato il 25 febbraio 2022.
Help identifying missing components
Hey all. Recently picked up a steam deck second hand from someone which isn't working after an SSD replacement. Turns out some SMD's have been knocked off the board. This is a F7A revision board. The parts missing can be found in the attached images. Any help would be huge.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Lucky for you I have one of these boards kicking around that I use mostly for things like this. I took the capacitors off and measured out of circuit because capacitance readings are real finicky. And I almost lost one of them that launched itself onto my microscope light. Also pardon the crud this board was covered in thermal paste when I got it and I am still finding it in little crevices.
  • Red is a resistor (I think) measured about 3.5 ohms on my meter.
  • Orange a capacitor that measured about 165 nano farad
  • Yellow is a capacitor that measured about 5.5 micro farad
Not sure of voltages and I didn't take the time to figure out sizes of components, but I figured the actual specs will be thew hardest the get anyway.
Punteggio 1
1 Commento:
Thanks for getting this back to me! Just a question, is it possible that red could be an inductor?
da
Aggiungi la tua risposta
Joshua Turner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 133
