Salta al contenuto principale
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Why is my iPad not able to do anything useful
I have this iPad 2 which had this iPad disabled connect to iTunes issue, I was able to restore it but lost everything but the funny part it is can even install Xender. All it says is iPad is not compatible with this app, same applesize for every app , what should I do, it makes the iPad completely useless
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you backup to iCloud? I suspect you are hitting newer iPad apps that your iPad can’t run. You are likely limited to the older apps which have been removed from the iTunes Store.
Punteggio 0
Aggiungi la tua risposta
Joe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 54
