To address the power issues you're facing with your Game Gear, you'll want to focus on several key components that are responsible for providing the proper voltages. Based on the symptoms you've described (the power LED turning on but no screen, 5V pins showing incorrect voltage, and the 34V pin dropping after a few seconds), here are the main components to check and potentially replace:
The Game Gear power board uses voltage regulators to step down the voltage from the battery to the required levels for various components (including the 5V for the logic and the 34V for the screen).
- 5V Regulator: This is critical for powering the logic board and other low-power components. If this regulator is damaged, it can lead to incorrect voltage levels being supplied to the circuit.
- 34V Regulator: This regulates the higher voltage needed for the screen and other high-power components. If this regulator isn't functioning properly, the screen will not work, even if the power LED is on.
- Measure Output Voltage: If the 5V and 34V outputs are incorrect or unstable, it's likely the regulators are damaged.
- Visual Inspection: Look for any signs of damage (e.g., burnt marks, overheating, or distortion). A burnt or damaged regulator will usually show visible signs like discoloration or residue.
- 5V Regulator: Often an LM7805 or a similar linear regulator (or sometimes a buck converter in some designs).
- 34V Regulator: Could be a custom-designed switch-mode power supply (SMPS) chip or a high-voltage step-up converter.
Replace any damaged regulators with compatible parts. Be sure to match the output voltage and current ratings (if specified) of the original regulators.
Capacitors are responsible for stabilizing voltage and filtering power. They can be damaged from power surges or prolonged use, leading to instability in the power supply.
- Visual Inspection: Check for bulging, leaking, or cracked capacitors. These are common signs of failure.
- ESR Testing: You can test the Equivalent Series Resistance (ESR) of capacitors with an ESR meter to check for damage (higher ESR indicates damage).
- Electrolytic Capacitors: Look for larger electrolytic capacitors (often found near voltage regulators or power input sections). If any appear damaged or swollen, replace them with parts of the same rating (voltage and capacitance).
- Ceramic Capacitors: These might be smaller and more difficult to spot, but if damaged, they can also affect power stability.
Diodes and transistors help manage the flow of current, preventing backflow or regulating switching. If any of these components are shorted or open, they could prevent the correct voltage from reaching parts of the Game Gear, including the screen.
- Use a multimeter to test diodes (in diode mode) and transistors (in continuity mode) to ensure they are functioning properly.
- If you find any faulty diodes or transistors, replace them with the same part numbers.
- If there is a fuse in the power input section, ensure it hasn't blown during testing. If the fuse is blown, it could cause the power circuit to malfunction and prevent proper voltage regulation.
- Solution: Inspect and replace any blown fuses.
If the power issue is fixed but the screen still doesn't turn on, it's possible the screen's backlight driver or the LCD itself is faulty. However, this is secondary to the power board issues.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
