Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Difference between iPhone 4 and 4G Digitizers?
Is there a difference between the digitizer and LCD between an iPhone 4 and an iPhone 4 4G? Are all iPhone 4 phones 4G? I'm looking to buy a replacement screen for my iPhone 4, but all the ones I find are being called iPhone 4 4G...will it work as long as it's the AT&T model?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
6 Risposte
Soluzione Prescelta
The digitizers are all the same. The only difference is in the screen mounting bracket, the spacing of the screws tabs are all different on the 3 different iPhone 4.
Regarding 4G, Apple considers the iPhone 4S to be a 4G capable phone. I think Apple is wrong. But when iPhone 4S on iOS 5.1 achieves optimum through-put the iPhone screen will display 4G next to the Carrier Name.
Vendors will even worse use 4G to mean, any of the 3 different iPhone 4, which is bad. The 3 iPhone 4 are:
iPhone 4 GSM
iPhone 4 CDMA
iPhone 4S
Punteggio 2
1 Commento:
If I was looking to buy a charger port for my verizon iPhone 4 3g would the 4gs port fit the same.
da
Risposta Più Utile
rdburkh , "None of the iPhones on the market support 4G service, which provides faster data connections on mobile phone networks than the standard existing 3G networks. The confusion may stem from the fact that many of these users probably have the iPhone 4, which itself succeeded the third-generation iPhone 3G and 3GS. But the "4" in the name means only that it's the fourth generation of the phone itself, not the service. AT&T(T) and Verizon(V)subscribers can get only 3G data coverage, as indicated by the little "3G" icon in the upper left-hand corner of the phone." from here and many other places. We are using buzzwords to describe a 4th generation iPhone, but it is not a 4G network. Anyhow, you are looking for a digitizer for the 4th generation iPhone. Remember that the LCD and digitizer are fused together, so if you need to replace the touch screen (digitizer, I strongly urge you to purchase the whole display assembly. You can buy individual pieces, but it is virtually impossible to remove the old ones, and most often leads to a broken LCD. They are available right here iPhone 4 (GSM/AT&T) Screen and places like this.Hope this helps, good luck.
Immagine iPhone 4 (GSM/AT&T) Screen
Prodotto
$24.99
Punteggio 2
AT&T and Version iPhone 4 LCD Digitizer difference is the frame. LCD and digitizer are compatible, only the supporting frame has a little difference.Please see below picture.
Are you clear now?
Punteggio 1
there's a bad batch of iphone 4s lcd assemblies going around, just purchased 5 of them, 3 white 3 black... all 3 black were bad, they don't fit, there's a good extra millimeter at least in thickness difference when you compare them to a good one, if you try to force it down then you'll end up with a white hazy ring around the screen from the pressure put on the LCD, these are OEM lcd's as well (apple on the cable), I bought these locally too, not straight from China on Ebay... makes me nervous about buying any online, atleast locally I can take them back and now check what he gives me for the giant gap between the lcd and the digitizer! If you get one that doesn't fit nicely, that's the problem
Punteggio 0
the digitizers and LCD are fused together,, Both digitizers are totally the same. iPhone 4 Digitizers are compatible with 4G, vice versa......http://www.prezzydeal.com/lcd-touch-digi...
Punteggio 0
so i can purchase an iphone 4g screen, and it will fit into my iphone 4?
Punteggio 0
1 Commento:
Check to be certain you do not have iPhone 4S, if 4S you need 4S screen.
If it is iPhone 4, then there at 2 types, GSM and CDMA screens. If your iPhone 4 has a SIM tray, get the iPhone 4 GSM screen (this is the one for ATT).
da
Aggiungi la tua risposta
rdburkh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 35,671
