Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
replaced battery depleting rapidly
i replaced my macbook air 13 inch, early 2015 battery, as it was running out of power in a few hours.
I replaced it with IFIXIT battery, it seemed to work well for the 1st few days. since then it has begun to run out of power at the same rate. even when the compute is shut down, and restarted the power is decreased, substantially than when it was shut down.
On standby power is depleted within a few hours
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
The first step would be to do a SMC & PRAM Reset and see if that made any difference.
Then install coconutBattery and post the reports on here for us to see.
It might be a good idea to test with both v3.918 & v4.01 depending on what OS your running on the unit.
Punteggio 2
Aggiungi la tua risposta
mjmd96733 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 2
Ultimi 30 giorni: 12
Tutti i Tempi: 134
