Salta al contenuto principale
Released Sept 2020, Identified as model T2250 on underside label
2 Domande Visualizza tutte
My dust bin has fallen out two days in a row.
Out robovac runs at night. For the last two mornings when I get up the dust collector bin is in the middle of the floor. The robovac is docked and charging. Any ideas what the problem could be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi Bobbi
It sounds like any of the following
  • loose tolerances or ware on the plastic guides holding it in place
  • loose release button
  • something it runs over pulls on the dust box, and removes it
Check if the fit of the dust box has become looser over time, and if there is a part of the floor that's unlevel and could catch the box, disconnecting it.
If so, consider using a small layer of tape to add some thickness to the mounting points to better hold it in place
Punteggio 0
Aggiungi la tua risposta
Bobbi Kiser sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 18
