Salta al contenuto principale
Repair guides and support for top and front loading Whirlpool brand washers.
Off Balance when spinning
Whirlpool LSQ7030LQ0 washer. Off balance when it spins. I have replace both sets of suspension pads, all 4 suspension springs and checked that the balance ring has fluid in it. What else can it be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Does it do it if you spin it empty? If not, then it is the clothes distribution.
Punteggio 0
2 Commenti:
Yes. It does it empty. I just noticed that it is rubbing the bottom of the tub ring as it spins to the point that it is creating a bur on it.
da
There is a part, I have never replaced one but I have heard others replace them, under the tub. I can't remember what they called it. Could be a stem, seal and bearing. It isn't an easy replacement but it can be done. That would tilt the tub and cause your symptoms, I suppose.
da
Aggiungi la tua risposta
Randall Tipton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 108
