Salta al contenuto principale
The Bose SoundLink Mini II is a Wireless Bluetooth Speaker that delivers high quality audio from a compact design. The device weighs approximately 1.5 pounds and has a Bluetooth range advertised up to 30 feet. The device was released after June 26, 2015 and is Identified by model number 725192-1110.
blinking red light and does not charge
the blinking red light appears on the power button when i plug the charger and does nothing
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Gday, try these few things...
Reset
  1. Disconnect the speaker from power.
  2. Hold the Power button for 10 seconds until the device powers off.
  3. Reconnect the speaker to the charger and check if it charges properly.
Update
Outdated firmware can cause charging issues:
  1. Download the Bose Updater Software from Bose's website.
  2. Connect your speaker to your computer via USB and follow the instructions to update the firmware.
  3. https://www.bose.co.nz/en_nz/support/art...
Check the cable and such, otherwise could be some sort of damage to the battery.
Punteggio 0
Aggiungi la tua risposta
Eever Paul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 318
