Salta al contenuto principale
Informazioni sulla riparazione, smontaggio e risoluzione dei problemi per lo smartphone di punta "più piccolo" di Apple del 2023, lanciato il 22 settembre. È dotato di un display OLED ProMotion da 6,1", un sistema di fotocamere posteriori a tripla lente e 5G. Successore dell'iPhone 14 Pro.
Camera won’t calibrate
Camera won’t calibrate. Keeps saying no objects found, restarts camera & goes back to finish repair.
Questa è una buona domanda?
Punteggio 1
2 Commenti:
You probably have a ripped camera flex or some dirt between the connectors. You could try to disconnect the cameras again, clean the connectors with some IPA and reconnect. Be sure to check the flex cables for rips or hard fold lines.
da
Camera was cleaned & checked, not sure I want to go to the trouble of opening it again. Camera works fine just won’t calibrate
da
Aggiungi un commento
1 Risposta
Did you use an original part from Apple? As long as you see an preview, when you do the calibration, make sure there are objects within your surrounding. This can be items on your desk or furniture in the room. This proces can be a bit long but just keep turning the phone until is says finished. Hope this helps.
Punteggio 0
2 Commenti:
The camera was purchased on ifixit, when I do the calibration it says Apple part . I’ve made sure there’s objects in view, it doesn’t recognize them & they are large objects. I get the same message over & over. Then it restarts & the same message appears that I need to restart & finish repair . I’ve tried this many times & it just won’t calibrate.
da
I took my camera to a repair business and now mine is getting the same message. The camera works great just can’t seem to locate item to calibrate on.
da
Aggiungi la tua risposta
Hairstylistroxx sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 51
Tutti i Tempi: 505
