Salta al contenuto principale
Repair guides and support for water softening systems.
5 Domande Visualizza tutte
CSI signature series (1) control valve troubleshooting
Hi we have error code 3 which is an issue with the control valve? I think I need to take the cover off and check for debris? The manual is very vague and unhelpful.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@shellyhyatt take a look at this CSI Signature Series SM and see if that pertains to your valve as well. Error 3 - Encoder is not sending a signal (Valve requires service to continue)
Yes, I would definitely consider opening it up and to take a look at it. See what you find. You could be looking at debris as well as corrosion etc.
Punteggio 0
1 Commento:
Yup! Ty - I have the paper manual and all it has it that code explanation and the exploded diagrams. I will try to find the screws and see what I can do/see:)
da
Aggiungi la tua risposta
Shelly Hyatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 53
