Salta al contenuto principale
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
Heating issue. Thinking of thermal paste it again?
My laptop is heating a lot. I'm thinking of changing my thermal paste and cleaning dust inside it also, or i should do something else, like expanding RAM.
Please help it's heating like a heater in cold season.
Thanks 😊
Questa è una buona domanda?
Punteggio 0
1 Commento:
Is the fan running and blowing air? I would start with that, and with cleaning the fan and heatsink it blows air through with some compressed air - try to prevent the fan from spinning while you clean it (clean it while it is turned off).
da
Aggiungi un commento
1 Risposta
Firstly, check the temperature of the CPU using Speccy.
Is it also hot when idle? If so, then some background process might be using the resources.
Check Task Manager process list sorting by CPU usage, to see what's using the CPU power.
Then clean your computer with some compressed air, maybe that'll be enough.
However if you haven't replaced the thermal paste in some years, it would be a good idea to do so.
Punteggio 0
Aggiungi la tua risposta
Aakash sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 22
