Dies after filling up with gas
I've had this problem for awhile, but it nearly got me hit today... Sometimes when I fill my van up with gas, it will start up fine, run for about 2 minutes, then idle really rough and die (like if you pull out of the station and hit a red light/stop light and waiting to make a left). I've also had it die while I was moving a few times... It also didn't seem like it wanted to start after it died, it never does... but after I did get it restarted, it drove really rough. It's weird though in that I left for work about an hour later and it ran fine the whole way. Any ideas?
Questa è una buona domanda?
Can be caused by multiple things. Is your service engine light on? When was the last time your fuel filter got replaced? Possible a bad fuel pump, bad fuel pump relay or bad sensor.
da oldturkey03
No check engine lights, did the key thing and no codes popped up, fuel filter got replaced at ~100k miles when it was misfiring on 3 cylinders. It runs great any other time, but when I fill it up it'll die... and it's only if I completely fill it up, if I only put like a quarter tank in it will be fine. I read somewhere that the EVAP system is messed up?
da Skippy722
My 2004 is doing the same thing! No check engine lights and only right after I fill it up. Maby I should just not fuel it any more LOL
da James Kressman
My 210 Dodge Caravan sometimes die at a traffic stop or on a slow turn when I have 1/4 tank of gas or less...Could this be bad gas?
da DodgeProblem
