Salta al contenuto principale
Guides and repair information for the LG Exalt VN220. The LG Exalt VN220 (also called the LG Exalt or Exalt LTE) is a flip phone released in 2018.
Usb charging port issue?
why is my phone not charging only when lying in certain position?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Replacing the charging port is the most common solution for the issue you're having. The charging port will need to be soldered on. Since it's a delicate job, either make sure you know what you're doing or find someone that can help you solder it on.
This is the part you need. but again needs to be soldered onto the board.
Punteggio 0
Aggiungi la tua risposta
Benzion sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 59
