Salta al contenuto principale
Il Meta Quest 2 (ex Oculus Quest 2) è stato lanciato a ottobre 2020 ed è il successore dell'Oculus Quest.
Turning on automaticity when charging
Hey there, so my quest 2 is having a issue where whenever it’s plugged in to charge it will power back on, I have tried everything to troubleshoot shoot and think it’s a technical issue was wondering if you ever seen this before or know how to fix it
I have swapped the proximity sensor with a good one to see if that was it bc I thought it could be but nope still same issue
Only other thing I could possibly think is the usb charger port/cable but I’m not a pro when it comes to small device repairs so don’t wanna risk it without more details and testing
Idk how this question works but if needed my email is tntn3rd@gmail.com
Questa è una buona domanda?
Punteggio 0
2 Commenti
Yes it is fully powered off and no it is not the charger cable
I have two quests and only one has this issue
(It isn’t a user issue)
da
Does it actually fully turn on?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
After trouble shooting for a while and trying everything from the most basic fixes to complicated ones I was able to fix it
I had to replace the charger/port flex cable to fix the issue and to clarify I don’t mean the charger cable I mean the flex cable inside of the headset it self so I took it apart and replaced it with a new one
Sure this wasn’t a huge issue bc the headset was fully functional but it was an issue nonetheless and I have OCD so I had to fix it for the life of me lol
Punteggio 0
Is the oculus fully powered off, or is it in sleep mode?
Punteggio 0
1 Commento:
Yes it is fully powered off, the issue had to do with the power cable
da
Aggiungi la tua risposta
TnTN3Rd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 38
Tutti i Tempi: 547
