Salta al contenuto principale
Released in April 2019, the Roborock S5 robotic vacuum cleaner is the base model of the Roborock S5 Max. Like most Roborock vacuums, it has LiDAR navigation and a high capacity dust bin.
WiFi upgrade not compatible with Roborock S5
My WiFi router has been upgraded to 5G and is not compatible with my Roborock S5 anymore.. It only connects to a 2G.. Which I don't have... Is there any way to upgrade the software to get it to work?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hello,
Like a lot of IoT equipments, the Roborock S50 is hardware limited to 2.4GHz Wi-Fi. So, you can't connect it to a 5GHz Wi-Fi network.
Can you give me the model number and brand of your Wi-Fi router? I didn't know that Wi-Fi router without 2.4GHz existed. Maybe you can enable it somewhere in its configuration menu.
Best regards,
lechercheur123
Punteggio 0
Wifi frequencies are hardware, not software. You could buy a 2.4GHz AP (https://tinyurl.com/twopointfourghz-amaz... was at the top of the list for me) and connect your Roborock S5 to that, but otherwise, no.
Punteggio 0
Aggiungi la tua risposta
Lilac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 196
