Salta al contenuto principale
The Black+Decker LSW20 is a 20-Volt Lithium-Ion Cordless Leaf Sweeper designed for clearing debris from hard surfaces such as patios, decks, and walkways, featuring a single-speed motor with an airspeed of 120 mph and weighing 3.7 pounds.
Grinding noise when turning off
Why does my leaf blower grind when turning if off?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Well I had a black and decker shop vac that did that and I progressively got worse so I drilled a tiny hole to where the main bearings are injected grease and oil mixture and got another 6 months out of it. Personally I think it's a bad design anytime bearings run dry. But who knows water or dirt may have accelerated the problem.
Punteggio 0
Aggiungi la tua risposta
QuartzNCoal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 163
